[mapguide-trac] #1051: MapGuide exhausts FDO connections during Fusion selection
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jul 27 19:24:53 EDT 2009
   Reporter:  jbirch           |       Owner:
       Type:  defect           |      Status:  new
   Priority:  high             |   Milestone:  2.1
  Component:  Feature Service  |     Version:  2.1.0
   Severity:  blocker          |    Keywords:
External_id:                   |
 This problem was initially [http://n2.nabble.com/MapGuide-runs-out-of-FDO-
 connections-under-Fusion-MGOS-2.1-Beta-td3281668.html#a3281668 surfaced on
 the Users mailing list], and has been traced down a few false paths. (
 #1039 , [/fusion/ticket/229 Fusion #229] )
 After Andy's most [http://n2.nabble.com/FW%3A--mapguide-users--MapGuide-
 runs-out-of-FDO-connections-under-Fusion-MGOS-2.1-Beta-
 td3287689.html#a3336162 recent email to the -internals list] I spent some
 time trying to figure this out.  I'd like to confirm that it was pretty
 easy for me to duplicate this problem in my environment:
  - Edit serverconfig.ini, setting !DataConnectionPoolSize to 20
  - Restart !MapGuide
  - Zoom in and start selecting
 When I reach some small number of selections (15-20), no further
 operations work.
 This is REALLY bizarre that the !DataConnectionPoolSize affects this
 problem because I have the SDF provided excluded from connection pooling.
 (same as Andy indicated).
 Just to try my hunch, I went through and changed all of my Fusion app's:
 $map = new MgMap();
 $map->Create($resourceService, $resourceID, $mapTitle);
 $map = new MgMap();
 $map->Open($resourceService, $mapName);
 $map->Save($resourceService);
 to the newer:
 $map = new MgMap($siteConnection);
 $map->Create($resourceID, $mapTitle);
 $map->Open($mapName);
 $map->Save();
 This had absolutely no effect on the problem.  So much for hunches.
 I'm convinced that it's a problem inside of !MapGuide that Fusion just
 happens to be exercising with its different selection methodology.  I am
 also convinced that this is a regression; the exact same map and
 application running on a 2.0.x server do not exhibit this behaviour.
 This is going to be a HUGE issue for anyone using Fusion.  I'm at the end
 of things I can do to investigate this; I think it needs some internal
 uber-coder attention...
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1051>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
