[mapguide-trac] #1051: MapGuide exhausts FDO connections during Fusion selection
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jul 30 17:01:13 EDT 2009
 Reporter:  jbirch           |         Owner:  trevorwekel
     Type:  defect           |        Status:  assigned
 Priority:  high             |     Milestone:  2.1
Component:  Feature Service  |       Version:  2.1.0
 Severity:  blocker          |    Resolution:
 Keywords:                   |   External_id:
Changes (by trevorwekel):
 * cc: pagameba (added)
  * owner:  => trevorwekel
  * status:  new => assigned
Comment:
 I have started some testing with the unofficial build Jason just posted.
 Jason was kind enough to supply me with a test map.  The issue is not so
 cut and dry.  It depends on the viewer used.
 The Ajax viewer does not hold on to data connections during selection.
 Selections are highlighted correctly and the property pane updates
 correctly.
 The Fusion viewer does hold on to data connections during selection.  In
 addition, my testing seems to indicate that the selection is not drawn to
 the screen but the property pane is updated correctly.
 I will keep working on it and update the ticket as I make further
 progress.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1051#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
