[mapguide-trac] #1013: Make BIDI an option via serverconfig.ini
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 11 01:56:29 EDT 2009
 Reporter:  zspitzer           |         Owner:
     Type:  enhancement        |        Status:  new
 Priority:  low                |     Milestone:  2.1
Component:  Rendering Service  |       Version:  2.1.0
 Severity:  trivial            |    Resolution:
 Keywords:                     |   External_id:
Comment (by waltweltonlair):
 Comment from Traian:
   When I prototyped this, I had code to detect if the string is plain
 ASCII, in which case I did not pass it to the reordering code.  This would
 reduce your 5% overhead to nearly 0.
 I've asked Traian if he still has that code laying around, and if so we
 could consider adding it.  If it reduces the overhead to near 0 then
 that's better than another serverconfig option.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1013#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
