[mapguide-trac] #1022: [MAPAGENT] QUERYMAPFEATURES - Error spatial operator
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 22 13:00:58 EDT 2009
   Reporter:  lgoubet    |       Owner:
       Type:  defect     |      Status:  new
   Priority:  medium     |   Milestone:
  Component:  Map Agent  |     Version:  2.0.2
   Severity:  minor      |    Keywords:  QUERYMAPFEATURES, mapagent, HttpQueryMapFeatures
External_id:             |
 If I use
 /mapguide2009/mapagent/mapagent.fcgi?OPERATION=QUERYMAPFEATURES&VERSION=1.0.0&PERSIST=1&MAPNAME=MACARTE&SESSION=
 e4433420-ffff-ffff-8000-
 005056c00001_fr_7F0000010AF20AF10AF0&SEQ=0.5438243192685027&LAYERNAMES=LAYER1&GEOMETRY=CURVEPOLYGON
 ((985200.554430509 111930.547565891 (CIRCULARARCSEGMENT (990200.554430509
 106930.547565891, 995200.554430509 111930.547565891), CIRCULARARCSEGMENT
 (990200.554430509 116930.547565891, 985200.554430509
 111930.547565891))))&SELECTIONVARIANT=INTERSECTS&CLIENTAGENT=Ajax%20Viewer
 with operator INSIDE , it doesn't work.
 Is is possible to add the others spatial operators ?
 Or a explanation as a result for the client when the provider doesn't work
 The code is to the line 100 in the file
 MGOS\Web\src\HttpHandler\HttpQueryMapFeatures.cpp(102)
 Thanks you.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1022>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
