[mapguide-trac] #899: Installer: Feature conditions not re-evaluated when bound properties changed from UI
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 12 08:27:09 EDT 2009
changed from UI
   Reporter:  jng       |       Owner:  jng
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:  2.1
  Component:  General   |     Version:
   Severity:  critical  |    Keywords:
External_id:            |
 Some installer features have conditions which will enable/disable the
 feature if the property condition evaluates to true/false. However
 changing the values of these properties does not cause re-evaluation of
 these feature conditions.
 Eg. Run the installer and choose IIS/.net configuration, this sets the
 property MGWEB_CONFIG to "IIS". When you come to choose features, the
 Apache Web Server feature is still visible and configurable, even though
 it should be disabled because its disable condition is (MGWEB_CONFIG =
 "IIS")
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/899>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
