[mapguide-trac] #896: Installer: Maestro shorcuts do not point to correct location
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 12 09:41:38 EDT 2009
 Reporter:  jbirch     |         Owner:  jng
     Type:  defect     |        Status:  new
 Priority:  low        |     Milestone:  2.1
Component:  Installer  |       Version:
 Severity:  trivial    |    Resolution:
 Keywords:             |   External_id:
Comment (by jng):
 No this is rather a limitation of paraffin (or a limitation of my
 knowledge of paraffin :-))
 When you run paraffin on Maestro's working directory you get the name of
 that directory as the top-level directory the installer will create.
 eg. If I run paraffin on ..\Tools\Maestro\Maestro\bin\Release (the default
 directory setting) it will create a top-level <Directory> named "Release".
 This doesn't match our expected top-level directory of "MapGuide Maestro".
 There is no way in paraffin to specify the id and/or name of the top-level
 directory. (argh!)
 The workaround is to make sure that the name of Maestro's staging area
 directory is "MapGuide Maestro".
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/896#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
