[mapguide-trac] #900: Connections in CLOSE_WAIT status never close and are not reused
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 12 12:07:41 EDT 2009
   Reporter:  amitmarty  |       Owner:
       Type:  defect     |      Status:  new
   Priority:  high       |   Milestone:
  Component:  Server     |     Version:  2.0.2
   Severity:  critical   |    Keywords:
External_id:             |
 Some of this was discussed in trac 726.[[BR]]
 But I believe that one should be left to the 55 connections issue which
 might be attributed to the ACE's ACE_WFMO_Reactor implementation in
 mapguide.
 [[BR]]
 My setup is Apache / Tomcat / Mapguide 2.0.2 with Ajax Viewer. / mysql db
 / Win 2003 Server
 [[BR]]
 When a user tries to access a map we load the base map (DWF) from the
 library and based on user options load a spatial feature layer from a
 mysql database.
 [[BR]]
 On the initial site load tomcat opens about 6 to 8 connections to port
 2811 on mapguide.
 After about 5 minutes of no activity on the map all these connections go
 to a close_wait status.
 [[BR]]
 If a user then tries a activity one of these 8 connections that are in
 close_wait will be reused and the user activity is processed. But the rest
 of the connections are never closed nor are they ever reused.
 [[BR]]
 As more users try to access the maps we start seeing a high amount of
 build up of these connections to map guide on port 2811 ( Client
 Connections ) and at some point I have to restart the mapguide server
 before the users can access maps again.
 [[BR]]
 Below is my workers.properties file, i have commented couple of the
 directives as they were deprecated.
 [[BR]]
 # Define 1 real worker using ajp13
 worker.list=worker1
 [[BR]]
 # Set properties for worker1 (ajp13)
 worker.worker1.type=ajp13
 worker.worker1.host=localhost
 worker.worker1.port=8009
 worker.worker1.lbfactor=50
 #Deprecated cachesize since 1.2.16 , replaced by connection_pool_size
 # For Apache autodiscovery is done to match the ThreadsPerChild Apache
 directive
 #worker.worker1.cachesize=10
 worker.worker1.cache_timeout=600
 worker.worker1.socket_keepalive=true
 #Deprecated since 1.2.16, replaced by connection_pool_timeout
 #worker.worker1.recycle_timeout=300
 worker.worker1.connect_timeout=10000
 worker.worker1.connection_pool_timeout=60
 [[BR]]
 What I would like to do is setup a debug environment with the source for
 mapguide server and web server extensions for java and try to first find
 what the initial connection are and then where the problem might be.
 [[BR]]
 Is there any documentation on how to setup such a env. ? Any Suggestion
 for debugging JNI ?
 Thanks for all the great work on Mapguide and any help you could extend.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/900>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
