[mapguide-trac] #816: ODBC column editor not correctly persisting key/geometry information
MapGuide Open Source trac_mapguide at osgeo.org
Fri Mar 13 01:59:32 EDT 2009
 Reporter:  jng       |         Owner:  ksgeograf
     Type:  defect    |        Status:  closed
 Priority:  high      |     Milestone:
Component:  Maestro   |       Version:
 Severity:  critical  |    Resolution:  fixed
 Keywords:            |   External_id:
Changes (by ksgeograf):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 I found the problem. It was possible to re-assign the primary key on a
 table, but if the table had no primary keys defined, it was not possible
 to assign a primary key.
 Fixed in r3729.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/816#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
