[mapguide-trac] #913: The coordinate system initialization failed. - Could not initialize the geodetic transformation.
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 19 05:44:07 EDT 2009
   Reporter:  zspitzer         |       Owner:
       Type:  defect           |      Status:  new
   Priority:  medium           |   Milestone:  2.1
  Component:  Mapping Service  |     Version:
   Severity:  blocker          |    Keywords:
External_id:                   |
 Using a repository which worked fine with MGE, I am getting this error
 with the 2.1 test installer
 <2009-03-19T20:36:34>   5068    Ajax Viewer     127.0.0.1
 Administrator
  Error: Failed to stylize layer: aug 06-ROADS - HWY
  StackTrace:
   - MgMappingUtil.StylizeLayers() line 763 file
 c:\osgeo\mapguide\server\src\services\mapping\MappingUtil.cpp
 the path is correct, the map is in GDA94
 MENTOR_DICTIONARY_PATH=C:\Program Files\OSGeo\MapGuide
 Server\CSMap\Dictionaries\
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/913>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
