[mapguide-trac] #917: Make CS-Map path a serverconfig.ini option
MapGuide Open Source trac_mapguide at osgeo.org
Mon Mar 23 20:24:49 EDT 2009
   Reporter:  zspitzer     |       Owner:
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  2.1
  Component:  Server       |     Version:  2.0.1
   Severity:  minor        |    Keywords:
External_id:               |
 currently when installing on windows, there is a requirement for a env
 path variable to be set for CS-MAP, this requires a reboot of the server
 which is painful.
 Moving the config for this into serverconfig.ini makes sense and also
 allows
 for future versions of mapguide to be run on the same box, without a
 conflict
 caused by using two versions of CS-MAP with only one env variable
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/917>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
