[mapguide-trac] #918: Inconsistence between mapguide and maestro in modul PointFeatureStyleEditor
MapGuide Open Source trac_mapguide at osgeo.org
Tue Mar 24 06:33:07 EDT 2009
   Reporter:  dl9ekd   |       Owner:  ksgeograf
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:  2.0.1
   Severity:  trivial  |    Keywords:
External_id:           |
 I've found a problem with an inconsistence between mapguide und maestro.
 The insertionpoint (reference point) in Symbol Style seems to have a
 different default value. Mapguides defaultvalue is 0.5, 0.5. The default
 value in Maestro seems to be 0.0, 0.0.
 So, if I edit a Layer in Autodesk Mapguidestudio and use the default
 value, the insertionpoint is not in the layerdefinition xml-file in
 repository. When i edit the layer later with Maestro, the insertionpoint
 is set to the Maestro-defaultvalue. Thats not so good.
 It would be great, if you fix the inconsistence, thanx
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/918>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
