[mapguide-trac] #931: Last segment in LineBuffer::CircularArcTo may not exactly end at arc end point
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 26 18:47:37 EDT 2009
point
   Reporter:  waltweltonlair  |       Owner:  waltweltonlair
       Type:  defect          |      Status:  new
   Priority:  medium          |   Milestone:  2.2
  Component:  General         |     Version:  2.1.0
   Severity:  minor           |    Keywords:
External_id:  1206094.02      |
 The LineBuffer::!CircularArcTo method converts an arc (specified using a
 mid point and end point) into a set of line segments in the !LineBuffer.
 Due to roundeff error, it's possible for the end point of the final
 generated line segment to not exactly match the supplied arc end point.
 One scenario where this can cause problems is if the arc segment is the
 last one in a closed contour (the arc's end point matches the contour's
 start point).  The generated end point may not match the start point, and
 so the contour does not end up being closed.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/931>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
