[mapguide-trac] #933: Installer: Install grid shift libraries as part of CS-Map Dictionaries
MapGuide Open Source trac_mapguide at osgeo.org
Fri Mar 27 11:46:47 EDT 2009
 Reporter:  jbirch     |         Owner:  jbirch
     Type:  task       |        Status:  assigned
 Priority:  medium     |     Milestone:  2.1
Component:  Installer  |       Version:  2.1.0
 Severity:  critical   |    Resolution:
 Keywords:             |   External_id:
Comment (by jbirch):
 Well, it's not exactly a requirement, but specifing and maintaining a
 directory
 You should be able to use -a=generate instead of -a=regen for your first
 pass, and then use -a=regen on subsequent passes.  Either that or use a
 text editor to manually replace c:\staging\ with your path on all of the
 file include .wxs files.
 This was required to ensure that the file names within the .wxs files
 didn't get new identifiers and guids every time the file list was
 regenerated.
 See r3767 (from ticket #932) for details :)
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/933#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
