[mapguide-trac] #726: MapGuide Stops Listening on 2811 (Client Connections)
MapGuide Open Source trac_mapguide at osgeo.org
Fri Mar 27 17:35:34 EDT 2009
 Reporter:  rbranson  |         Owner:
     Type:  defect    |        Status:  new
 Priority:  high      |     Milestone:
Component:  Server    |       Version:  2.0.2
 Severity:  trivial   |    Resolution:
 Keywords:            |   External_id:
Comment (by jbirch):
 More email on this in the internals group:
 http://tinyurl.com/ddnsyw
 I wonder if having the connections set to 100 in the serverconfig.ini file
 has anything to do with this.  Odd that the connections are being held
 open though, I wonder if the PHP API isn't closing them correctly.  Time
 for more blind testing I guess.  First thing I'm going to do is try
 lowering the client connections setting in serverconfig.ini, then I'll try
 running the PHP in cgi mode instead of ISAPI, and finally I'll try the
 same with the MapAgent.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/726#comment:23>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
