[mapguide-trac] #941: Out of Disk Space - Problems
MapGuide Open Source trac_mapguide at osgeo.org
Tue Mar 31 04:16:00 EDT 2009
 Reporter:  pielera    |         Owner:
     Type:  defect     |        Status:  new
 Priority:  low        |     Milestone:
Component:  Installer  |       Version:  2.1.0
 Severity:  major      |    Resolution:
 Keywords:             |   External_id:
Comment (by jng):
 How much disk space do you have on C drive?
 The installer extracts the msi and the bootstrapper to %TEMP% (which is
 usually defined as somewhere on C drive). The msi itself is around 450MB
 and it is uncompressed, meaning the installation size is around the same.
 Then factor in the amount of temp files that may be created from an
 installer of this size and soon you'll be past 1GB in no time.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/941#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
