[mapguide-trac] #957: Doesn't check for computer configuration, to see if there is the right .NET inveroment
MapGuide Open Source trac_mapguide at osgeo.org
Sun May 3 02:56:15 EDT 2009
inveroment
 Reporter:  nimcnaan   |         Owner:  nimcnaan
     Type:  defect     |        Status:  closed
 Priority:  low        |     Milestone:  2.1
Component:  Installer  |       Version:  2.1.0
 Severity:  trivial    |    Resolution:  fixed
 Keywords:             |   External_id:
Changes (by jbirch):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 This step has been integrated into the IIS 5 and IIS6 install paths when
 the .Net setup is chosen as the default.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/957#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
