[mapguide-trac] #975: Expose Help web pages through web tier
MapGuide Open Source trac_mapguide at osgeo.org
Sun May 3 03:42:14 EDT 2009
 Reporter:  pagameba     |         Owner:
     Type:  enhancement  |        Status:  closed
 Priority:  low          |     Milestone:
Component:  Installer    |       Version:  2.0.2
 Severity:  trivial      |    Resolution:  fixed
 Keywords:               |   External_id:
Changes (by jbirch):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I've moved help to be under the www/ directory, so can be addressed at:
 http://localhost[:8008]/mapguide/help/index.htm
 Or you can just use the handly hyperlink in your start menu.
 I did not add the !DirectoryIndex entry at this time.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/975#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
