[mapguide-trac] #977: rebuild of ace/Svc_Conf_l.cpp is failing on linux
MapGuide Open Source trac_mapguide at osgeo.org
Sun May 3 23:07:11 EDT 2009
   Reporter:  uvlite   |       Owner:
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  General  |     Version:  2.1.0
   Severity:  minor    |    Keywords:
External_id:           |
 oem build fails trying to regenerate the Svc_Conf_l.cpp file
 when this file is out of Date.
 This can happen in  a fresh checkout of repository on a CentOS52 machine.
 when the svn is setting file dates to checkout time.
 The workaround is to use touch to make sure that the regeneration is not
 triggered by make.
 At some point it migh be intersting to find out why calling lex during the
 OEM ace build is failing.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/977>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
