[mapguide-trac] #990: Maestro Save Map Obscure Message
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 20 06:53:56 EDT 2009
   Reporter:  crispinatime  |       Owner:
       Type:  enhancement   |      Status:  new
   Priority:  low           |   Milestone:  Maestro-1.0
  Component:  General       |     Version:
   Severity:  minor         |    Keywords:
External_id:                |
 If I create a new map, add a single layer but do NOT fill in the "Legend
 Label" and hit 'Save' I get the message below:
   "Failed in Validator: Object reference not set to an instance of an
 object"
 This may well fail the validator but the behaviour and message is non-
 intuitive -- can you please add an extra check for the "Legend Label" if
 this is a required value.
  Crispin
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/990>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
