[mapguide-trac] #273: Support for Oracle Coordinate Sytem 81989 (British National Grid)
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 20 07:11:58 EDT 2009
 Reporter:  crispinatime  |         Owner:
     Type:  defect        |        Status:  closed
 Priority:  low           |     Milestone:
Component:  General       |       Version:  1.2.0
 Severity:  minor         |    Resolution:  fixed
 Keywords:                |   External_id:
Changes (by crispinatime):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 All,
 Tested on new CS-Map enabled MapGuide 2.1 unofficial 0.7 and KingOra 0.8.9
 All OK apart from one case where featuresource is OracleSrid81989 and the
 mapdefinition is set to Arbitrary-XY.
 I can understand the message below but also think the with arbitrary-
 coords there should be no initialisation of a geodetic transform and
 coords are just passed through.  As I can set a CS-override on the
 featuresource this is also not so important.
  Crispin
 <2009-05-20T11:43:22>   2560    Ajax Viewer     127.0.0.1
 Administrator
  Error: Failed to stylize layer: HADES_MasterMap_81989
         The coordinate system initialization failed.
         Could not initialize the geodetic transformation.
  StackTrace:
   - MgMappingUtil.StylizeLayers() line 776 file
 c:\osgeo\mapguide_trunk\mgdev\server\src\services\mapping\MappingUtil.cpp
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/273#comment:9>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
