[mapguide-trac] #917: Make CS-Map path a serverconfig.ini option
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 20 15:58:59 EDT 2009
 Reporter:  zspitzer     |         Owner:
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:  2.1
Component:  Server       |       Version:  2.0.1
 Severity:  minor        |    Resolution:
 Keywords:               |   External_id:
Comment (by jbirch):
 It would be nice of, rather than removing the env var option, we could
 make the currently hard-coded default path a config file option.  Is there
 a way to determine which config file (web or server) to read from inside
 the CS api?
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/917#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
