[mapguide-trac] #997: Maestro: Create the Wix based MSI and move translation files into subfolders
MapGuide Open Source trac_mapguide at osgeo.org
Fri May 22 01:23:46 EDT 2009
subfolders
   Reporter:  ksgeograf  |       Owner:  ksgeograf
       Type:  defect     |      Status:  new
   Priority:  low        |   Milestone:  Maestro-2.0
  Component:  Maestro    |     Version:
   Severity:  trivial    |    Keywords:
External_id:             |
 The Wix code created by Jason/Jackie is an excellent starting point for
 getting rid of the annoying VS installer project.
 With the Wix based installer, it is now possible to select what languages
 to install, but that requires that I change the code to look for
 translation files in the subfolders.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/997>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
