[mapguide-trac] #1001: An extra FDO connection is created when doing selection on point layers
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 25 14:37:54 EDT 2009
 Reporter:  brucedechant       |         Owner:  brucedechant
     Type:  defect             |        Status:  new
 Priority:  medium             |     Milestone:  2.1
Component:  Rendering Service  |       Version:  2.0.2
 Severity:  minor              |    Resolution:
 Keywords:                     |   External_id:
Old description:
> The internal RenderForSelection() method of the Rendering service will
> create 2 FDO connections when dealing with point layers because of the
> setup/tear down sequence. This needs to be optimized so that only a
> single FDO connection is active at a time.
New description:
 The internal !RenderForSelection() method of the Rendering service will
 setup/tear down sequence. This needs to be optimized so that only a single
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1001#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
