[mapguide-trac] #1005: Error processing DWF file containing resource folder names that differ only in case
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 27 14:46:26 EDT 2009
in case
   Reporter:  waltweltonlair            |       Owner:  waltweltonlair
       Type:  defect                    |      Status:  new
   Priority:  high                      |   Milestone:  2.1
  Component:  General                   |     Version:  2.1.0
   Severity:  major                     |    Keywords:
External_id:  785615; 1144842; 1204661  |
 DWF packages are basically zip files, and resources are stored in folders
 inside the package.  It's possible for two resource paths in the package
 to vary only in case.  For a DWF like this the zip package library will
 fail to extract such resources.  That's because it uses a case-insensitive
 comparison to locate files inside the package.
 In my case I encountered the problem with a large DWF symbol library.
 Many of the symbols could not be loaded due to this problem.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1005>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
