[mapguide-trac] #1006: Web Layout not working
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 28 02:47:07 EDT 2009
   Reporter:  JackOfHearts  |       Owner:
       Type:  defect        |      Status:  new
   Priority:  high          |   Milestone:
  Component:  General       |     Version:  2.1.0
   Severity:  major         |    Keywords:  web, layout
External_id:                |
 I have installed a MG 2.1 beta on a "clean" machine, IIS configuration
 with .NET, on Windows XP SP2, IIS 5.1, .NET 2.0. Installation worked
 perfectly, without any problems.
 Then I installed a trial version of Mapguide Studio 2010 and tried to make
 a web with only one shapefile. Everything worked as always until I got to
 web layout, it throws an error.
 Copyright (C) 2004-2009 by Autodesk, Inc.
 This library is free software; you can redistribute it and/or
 modify it under the terms of version 2.1 of the GNU Lesser
 General Public License as published by the Free Software Foundation.
 This library is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
 Lesser General Public License for more details.
 You should have received a copy of the GNU Lesser General Public
 License along with this library; if not, write to the Free Software
 Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
 <%@ Page language="c#" %>
 <%@ Import Namespace="System" %>
 <%@ Import Namespace="System.Collections.Specialized" %>
 <%@ Import Namespace="System.IO" %>
 <%@ Import Namespace="OSGeo.MapGuide" %>
 <script runat="server">int forDwf=0;</script>
 <!-- #Include File="mainframe.aspx -->
 also when I want to see that page in browser it also throws me that error.
 Funny thing is that I can see that shapefile in map preview, but not in
 web layout.
 Then I tried to do the same thing in Maestro 1.0.9 but i get the same
 error in browser.
 I have experience with previous versions of MGOS.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1006>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
