[mapguide-trac] #1006: Web Layout not working
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 28 09:42:48 EDT 2009
 Reporter:  JackOfHearts  |         Owner:
     Type:  defect        |        Status:  new
 Priority:  high          |     Milestone:
Component:  General       |       Version:  2.1.0
 Severity:  major         |    Resolution:
 Keywords:  web, layout   |   External_id:
Comment (by JackOfHearts):
 I'm not very familiar with IIS, but I compared 2.0 instalation of IIS and
 there are some differences. First, I thing that mapviewerajax is not
 working, second, mapviewernet is not created as and application. Both of
 them have low Application protections compared to MGOS 2.0 installation
 where these settings are set to high.
 Then, both of them (mapviewerajax and mapviewernet) have different
 (compared to MGOS 2.0) Application Mappings in Configuration settings.
 In HTTP Headers, both of them do not have Custom HTTP headers set to X
 -Powered-By: ASP.NET.
 MIME Map does not have file type .json application/json
 Document tab, has only Default.aspx compared to Default.apsx, index.php,
 index.html etc.
 All comparison is to MGOS 2.0 instalation with IIS and .NET configuration
 which works without any problem.
 I thing this is all of the differences. I hope it helps. I tired to set
 everything the same but with no success.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1006#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
