[mapguide-trac] #1021: Avoiding login window in an application using flexible fusion weblayout
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 3 06:23:44 EST 2009
 Reporter:  msuing            |         Owner:
     Type:  defect            |        Status:  reopened
 Priority:  high              |     Milestone:  2.2
Component:  Fusion Templates  |       Version:  2.0.2
 Severity:  blocker           |    Resolution:
 Keywords:                    |   External_id:
Comment (by poulet1212):
 I think both mechanisms of passing session value through url and Fusion
 init should be kept. Therefore the little code review above is required.
 Then, I think it's not very nice that mapguide displays at first time a
 login box and therefore your remark makes sense, it could log in with the
 "Anonymous" account by default.
 The only problem with that is noboby will be able to log in with a
 different account than "Anonymous", because the login box doesn't appear.
 A login widget would be a solution for this.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1021#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
