[mapguide-trac] #1137: decode xml string before rendering attribute in www\fusion\widgets\SelectionPanel.js
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 3 07:41:55 EST 2009
   Reporter:  poulet1212   |       Owner:
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Fusion       |     Version:  2.0.2
   Severity:  minor        |    Keywords:
External_id:               |
 SelectionPanel.js: in the renderFeature function, at line 403, the
 instruction:
 td.innerHTML = layerObj.getElementValue(featureIdx, i);
 outputs the requested attribute values for a selection.
 If a value contains html tags such as links, it won't be rendered as html
 but as simple text because the html tags are not decoded from the xml
 string. for example a "&lt;" should be decoded as "<" before it is passed
 to innerHTML.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1137>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
