[mapguide-trac] #1142: Maestro: Adding layers to map enhancement
MapGuide Open Source trac_mapguide at osgeo.org
Fri Nov 6 03:40:40 EST 2009
   Reporter:  jbirch       |       Owner:  ksgeograf
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:
   Severity:  minor        |    Keywords:
External_id:               |
 Currently adding many layers to a map from a different folder is tedious.
 Each time, you have to click all the way through the tree to find the
 resource you are looking for.
 I can think of two ways of addressing this:
 1) remember the last location a layer was added from when adding a new
 layer
 2) allow multi-select of resources to be effective in the layer addition
 tool (ie. allow multiple layers to be added with a single File-Open
 dialogue).
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1142>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
