[mapguide-trac] #1112: Maestro: please consider adding some inter-server migration tools
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 10 16:29:04 EST 2009
 Reporter:  jbirch       |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  assigned
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:
 Severity:  minor        |    Resolution:
 Keywords:               |   External_id:
Changes (by ksgeograf):
  * status:  new => assigned
Comment:
 Hmm, it will take some time to do, but it could be done.
 The obvious problem is the dataconnections which have local settings (as
 you point out).
 I imagine that a user can perform this on a map, a weblayout or a fusion
 application.
 A progress bar would show while evaluating what items to update.
 A dialog should show the required changes (overwrites).
 The user should be able to de-select a change, and featuresource
 overwrites should be disabled, if the featuresource is using external
 data. This can be determined by looking for the %MG_DATA_FILES% string in
 the connection properties.
 When the user clicks OK, simply copy all resources to the remote server.
 Perhaps it would be more efficient to just roll a package and send that to
 the server.
 Permissions are tricky, because the users may not exist on the remote
 server. For starters, permissions could be ignored.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1112#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
