[mapguide-trac] #1153: Update the default path to the Mentor dictionaries to use on the Linux, when the MENTOR_DICTIONARY_PATH is not defined in the system
MapGuide Open Source trac_mapguide at osgeo.org
Mon Nov 16 20:34:21 EST 2009
   Reporter:  hubu     |       Owner:  hubu
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:  2.2
  Component:  Fusion   |     Version:  2.1.0
   Severity:  blocker  |    Keywords:
External_id:  1276545  |
 This is a defect. On Linux, when the MENTOR_DICTIONARY_PATH  is not set,
 the default path of Mentor Dictionaries is still
 /opt/Autodesk/mapguideenterprise2010/share/gis/coordsys. This directory is
 not exist in MapGuide 2011. This issue will cause Fusion doesn't work on
 Linux. So we need to update it to
 /opt/Autodesk/mapguideenterprise2011/share/gis/coordsys.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1153>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
