[mapguide-trac] #1155: Maestro: would be useful to pre-fill the legend label with the same value as the layer name
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 17 19:27:24 EST 2009
as the layer name
 Reporter:  jbirch       |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Old description:
> When adding layers to a MapDefinition, it would be useful if Maestro
> could pre-fill the Legend Label field with the same value as the Name
> field.  This would allow the author to modify it if it is inappropriate,
> but would reduce the amount of initial authoring work if the default name
> is appropriate.
New description:
 When adding layers to a !MapDefinition, it would be useful if Maestro
 is appropriate.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1155#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
