[mapguide-trac] #1162: MgGwsFeatureReader does not work with left-out joins
MapGuide Open Source trac_mapguide at osgeo.org
Fri Nov 27 02:48:04 EST 2009
   Reporter:  Aleck    |       Owner:  Aleck
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  General  |     Version:  2.0.2
   Severity:  trivial  |    Keywords:
External_id:           |
 When GWS query engine is involved in querying features, an
 MgServerGwsFeatureReader will be created for reading features.
 In MgServerGwsFeatureReader::ReadNext() method, it'll get a right-side
 feature
 iterator for a left side feature using the following code:
 retVal = secondaryIter->ReadNext();
 If (retval)
         // return the right-side feature
 else
         m_bAdvancePrimaryIterator = true;
 Therefore, if there is no corresponding right-side feature, it'll skip the
 left
 side feature, which is wrong for left outer joins.
 The solution is to check if it is a left outer join. If so, the left-side
 feature still need to be returned with the right side feature property
 value set
 to NULL
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1162>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
