[mapguide-trac] #1126: Past fusion measure widget contribution
MapGuide Open Source trac_mapguide at osgeo.org
Mon Oct 26 13:48:09 EDT 2009
 Reporter:  poulet1212              |         Owner:
     Type:  enhancement             |        Status:  closed
 Priority:  medium                  |     Milestone:  2.1
Component:  Fusion                  |       Version:  2.0.2
 Severity:  minor                   |    Resolution:  invalid
 Keywords:  Fusion widgtet measure  |   External_id:
Changes (by pagameba):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Your contribution was added to fusion 1.0 (?) but I had some problems with
 the area thing (not specifically with your code IIRC).  When we started
 2.0, the widget was changed substantially to use the OpenLayers controls
 for measuring and a lot of the code was removed, but some of the options
 are still there with your comments!  Area support is finally enabled in
 the latest 2.0 branch and trunk versions I believe.
 I will close this ticket as invalid as I think we have finally addressed
 this issue.  Please reopen if you disagree.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1126#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
