[mapguide-trac] #1131: Load balancing doesn't support failover
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 27 17:52:02 EDT 2009
   Reporter:  brucedechant  |       Owner:  brucedechant
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:  2.2
  Component:  General       |     Version:  2.1.0
   Severity:  minor         |    Keywords:
External_id:                |
 The load balancing algorithm used in the web tier doesn't remove server's
 that are not responding.
 Example: In a 2 server site this shows up as a sequence of
 success/fail/success/fail/... operations because the load balancing
 algorithm is round robining between all of the servers in the list even
 "bad" ones.
 If a "bad" server is encountered it needs to be removed from the load
 balancing list of servers and periodically checked and added back in if it
 becomes "good" again.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1131>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
