[mapguide-trac] #1132: MgCoordinateSystemMgrs::ConvertFromLonLat gives wrong result in release mode
MapGuide Open Source trac_mapguide at osgeo.org
Wed Oct 28 18:04:40 EDT 2009
mode
   Reporter:  hugueswski  |       Owner:
       Type:  defect      |      Status:  new
   Priority:  high        |   Milestone:
  Component:  General     |     Version:  2.0.2
   Severity:  trivial     |    Keywords:
External_id:  1253378     |
 The call to the CsMap API CScalcMgrsFromLl uses strlen on the input string
 instead of sizeof
 In debug builds the default content of the string "szMgrs" is not the same
 as the one in release mode and provides unpredictable output strings that
 can range from no output to the expected output.
 The computed value was correct but the string result is truncated
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1132>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
