[mapguide-trac] #1021: Avoiding login window in an application using flexible fusion weblayout
MapGuide Open Source trac_mapguide at osgeo.org
Sat Oct 31 10:31:00 EDT 2009
 Reporter:  msuing            |         Owner:
     Type:  defect            |        Status:  closed
 Priority:  high              |     Milestone:  2.2
Component:  Fusion Templates  |       Version:  2.0.2
 Severity:  blocker           |    Resolution:  worksforme
 Keywords:                    |   External_id:
Changes (by poulet1212):
  * status:  new => closed
  * resolution:  => worksforme
Comment:
 Ok, after a little time I think I've found the problem:
 Look at ApplicationDefinition.js method:getAppDef, about the line 144.
 This method will request the application definition from the server via
 the mapagent GETRESOURCECONTENT service.
 If you supply a session param, I'm afraid the following line will suppress
 it, and because Mapagent will not receive the session parameter, it will
 simply request it.
 if (xhr) {
         this.sessionId = xhr.responseText;
         Fusion.sessionId = this.sessionId;
 The fact is in Firefox, the xhr value exists, but responseText is null, so
 the next line will cause Fusion.sessionId = null. That's it.
 To correct that, simply change the lines this, so that responseText must
 not be null to change the session Id:
 if (xhr){
       if(xhr.responseText){
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1021#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
