[mapguide-trac] #1310: Package builder will crash w/ unhandled exception if the starting point doesn't have a ending slash
MapGuide Open Source trac_mapguide at osgeo.org
Wed Apr 7 22:25:35 EDT 2010
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-2.1
  Component:  Maestro  |     Version:  2.1.0
   Severity:  trivial  |    Keywords:  package builder
External_id:           |
 The Create Package UI should fix the starting point value so that it
 conforms to the MgResourceIdentifier spec. (ie. If it is a folder resource
 identifier, it must end with a '/' character).
 Since only folders can be packaged anyway, the UI should auto-append a '/'
 character if it turns out the starting point value doesn't have one.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1310>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
