[mapguide-trac] #1204: Maestro: consider adding a preview function for symbol definitions
MapGuide Open Source trac_mapguide at osgeo.org
Thu Apr 8 01:20:41 EDT 2010
 Reporter:  jbirch       |         Owner:  jng
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:  Maestro-2.1
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Changes (by jng):
  * owner:  ksgeograf => jng
  * status:  assigned => new
Comment:
 Without knowing much about symbol definitions, I guess the simplest way to
 do this is to have a set of "pre-baked" SDF files that each contain lines,
 points, polygons and various permutations thereof.
 Then based on the particular geometry types detected in the symbol
 definition, we load in the matching pre-baked SDF file into a session
 repository and generate a preview layer definition off of this SDF file.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1204#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
