[mapguide-trac] #1313: ODBC FDO connection to SQL Server fails with a password containing an ampersand
MapGuide Open Source trac_mapguide at osgeo.org
Thu Apr 8 02:20:15 EDT 2010
ampersand
   Reporter:  warrenmedernach  |       Owner:
       Type:  defect           |      Status:  new
   Priority:  low              |   Milestone:
  Component:  General          |     Version:  2.1.0
   Severity:  minor            |    Keywords:
External_id:                   |
 When attempting to connect to SQL Server via the ODBC FDO Provider, if the
 SQL Server username password contains an & (ampersand) character, the
 connection will fail.
 If this is being tested in a localized environment with Studio on the same
 machine as the MG Server the following error message is returned if
 '''''Bob&Doug''''' is used as a password:
   Feature Source - Unterminated entity reference, 'Doug'
 If however, this is tested in an environment with MG and SQL Server on
 seperate machines and accessing with Studio on a client machine, the error
 returned is:
   response returned status code 502 (BadGateway)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1313>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
