[mapguide-trac] #1323: Set NLSPATH in server so that FDO messages show up
MapGuide Open Source trac_mapguide at osgeo.org
Thu Apr 15 12:52:13 EDT 2010
   Reporter:  tomfukushima  |       Owner:  brucedechant
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:
  Component:  Server        |     Version:  2.1.0
   Severity:  minor         |    Keywords:
External_id:                |
 FDO uses the NLSPATH environment variable to find the messages stored in
 FDOMessage.cat.  If we set NLSPATH to %!FdoPath%/nls (where %!FdoPath% is
 the value of !FdoPath from the serverconfig.ini) as an "environment
 variable for the process" when the server starts then FDO should be able
 to give nicer messages.
 I think that FDO should be able to find the FDOMessage.cat file on its
 own, but until that happens; we can do this workaround. I have entered
 ticket http://trac.osgeo.org/fdo/ticket/640 for FDO, if that is addressed
 then this MG ticket could also be closed.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1323>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
