[mapguide-trac] #1322: Installer component updates to match RFC89
MapGuide Open Source trac_mapguide at osgeo.org
Fri Apr 16 11:58:54 EDT 2010
 Reporter:  jng        |         Owner:  jng
     Type:  task       |        Status:  new
 Priority:  high       |     Milestone:  2.2
Component:  Installer  |       Version:
 Severity:  major      |    Resolution:
 Keywords:             |   External_id:
Old description:
> The current binary distributions used by the installer are considerably
> out of date and may not work with the changes introduced in RFC89. So the
> following components will be updated:
>  * Apache
>  * PHP
> PHP will be updated to 5.3.2 (VC9 x86 Thread-Safe)
> The official httpd site does not offer a VC9 binary, but one is available
> from http://www.apachelounge.com so we'll use the binary distribution
> from there.
> To make way for a future x64 installer, these components will be put
> under Installer/Support/Web/x86 to indicate that these are 32-bit
> binaries
> Tomcat will be moved from Installer/Support/Web/Tomcat to
> Installer/Support/Web/x86/Tomcat
> Build scripts will be updated to ensure the staging area is prepared from
> the updated location.
New description:
  * Apache
  * PHP
 Apache will be updated to 2.2.11 (to match the version in Oem)
 from http://www.apachelounge.com so we'll use the binary distribution from
 there.
 To make way for a future x64 installer, these components will be put under
 Installer/Support/Web/x86 to indicate that these are 32-bit binaries
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1322#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
