[mapguide-trac] #1050: Bug in FdoProviderCapabilities-1.0.0.xsd
MapGuide Open Source trac_mapguide at osgeo.org
Fri Apr 16 12:51:10 EDT 2010
 Reporter:  ksgeograf  |         Owner:
     Type:  defect     |        Status:  new
 Priority:  low        |     Milestone:  2.2
Component:  General    |       Version:  2.0.2
 Severity:  trivial    |    Resolution:
 Keywords:             |   External_id:
Changes (by brucedechant):
  * milestone:  => 2.2
Old description:
> The element on line #269 is called FunctionDefinitionList, but the actual
> return value from GetProviderCapabilities is
> FunctionDefinitionCollection.
> Also, the return type enumeration does not have an empty type, which is
> required for functions which return void.
> To test this, simply issue the GETPROVIDERCAPABILITIES on the OSGeo.SDF
> provider and validate the results agains the xsd, as the OSGeo.SDF
> provider exhibits both issues.
New description:
 The element on line #269 is called !FunctionDefinitionList, but the actual
 return value from !GetProviderCapabilities is
 !FunctionDefinitionCollection.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1050#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
