[mapguide-trac] #1325: Fdo Provider Capabilities xml fix
MapGuide Open Source trac_mapguide at osgeo.org
Mon Apr 19 19:59:44 EDT 2010
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-2.1
  Component:  Maestro  |     Version:  2.1.0
   Severity:  trivial  |    Keywords:
External_id:           |
 The fix to #1050 has revealed that Maestro has been working with incorrect
 provider capabilities xml for quite some time. As a result, features which
 rely on this xml output, such as the Expression Editor may not function
 properly against > 2.1 servers in its current form.
 The solution as suggested by Tom Fukushima, is to transform the xml into
 its pre-2.2 form before deserialization only if we're connecting to a <=
 2.1 server.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1325>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
