[mapguide-trac] #1236: "Sticky" tooltips
MapGuide Open Source trac_mapguide at osgeo.org
Tue Apr 20 21:42:16 EDT 2010
 Reporter:  jng          |         Owner:
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:
Component:  AJAX Viewer  |       Version:
 Severity:  major        |    Resolution:
 Keywords:               |   External_id:
Changes (by jng):
  * summary:  Allow the tooltip to stay at the same position instead of
              following the mouse pointer. => "Sticky"
              tooltips
Old description:
> Currently tooltips will always follow the mouse pointer, as a result if
> there is any interactive content inside the tooltip, it is impossible to
> actually interact with the said content using the mouse.
> What the tooltip should ideally do is to stay at the position it was
> first displayed, and only disappear when the mouse pointer leaves the
> tooltip's bounding box. This allows for clicking of any interactive
> content inside the tooltip.
New description:
 What the tooltip should ideally do is to stay at the position it was first
 displayed, and only disappear when the mouse pointer leaves the tooltip's
 bounding box. This is how it's done in Fusion and allows for clicking of
 any interactive content inside the tooltip.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1236#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
