[mapguide-trac] #1332: Tile Cache should only be cleared if the saved Map Definition resource has changes in base layer
MapGuide Open Source trac_mapguide at osgeo.org
Tue Apr 27 01:00:47 EDT 2010
 Reporter:  jng           |         Owner:
     Type:  defect        |        Status:  new
 Priority:  high          |     Milestone:
Component:  Tile Service  |       Version:
 Severity:  critical      |    Resolution:
 Keywords:                |   External_id:
Old description:
> The Tile Cache invalidation logic should be more refined. Currently
> saving a Map Definition will invalidate the tile cache for that layer,
> even if there were no changes to the base layer settings.
> The Tile Cache should only be invalidated when there are changes found in
> the base layer section of the Map Definition. For example, adding dynamic
> layers to a Map Definition with tiled layers and saving that resource
> should not clear the tile cache as the tiles are still valid.
> Steps to reproduce:
> 1. View any web layout containing a map definition w/ tiled layers
> 2. A generated folder containing the tiles should be in the defined
> TileCache folder
> 3. Perform any change to this map definition that does not affect the
> base layers (eg. Changing the description, adding an untiled layer, etc)
> and save it.
> 4. That generated folder is now deleted. Nothing was changed in the base
> layer settings so this folder (and all generated tiles within) should
> have remained.
New description:
 The Tile Cache invalidation logic should be more refined. Currently saving
 a Map Definition will invalidate the tile cache for that layer, even if
 Steps to reproduce:
 TileCache folder
 and save it.
 layer settings so this folder (and all generated tiles within) should have
 remained.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1332#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
