[mapguide-trac] #1410: Avoid the use of solution folders in VS solution files
MapGuide Open Source trac_mapguide at osgeo.org
Tue Aug 3 09:43:13 EDT 2010
   Reporter:  jng           |       Owner:
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:
  Component:  Build System  |     Version:
   Severity:  trivial       |    Keywords:
External_id:                |
Description changed by jng:
Old description:
> If we want to lower the barrier for contribution to this project, I
> believe that the MGOS source should be buildable with Visual C++ 2008
> Express Edition.
> Unfortunately, express editions do not understand solution folders.
> WebTier.sln is the only solution file to use solution folders making it
> un-buildable in VC express.
> Solution folders should not be used in any VS solution files.
New description:
 Express Edition.
 Unfortunately, express editions do not understand the following:
  * Solution files with solution folders
  * Solution files with different project types
 Oem.sln has a C# project (SQLiteGUI), but it is not required for
 successful compilation.
 For VS express compatibility, solution files should not use folders and
 should only contain projects of one type.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1410#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
