[mapguide-trac] #1413: VS Express compilation support
MapGuide Open Source trac_mapguide at osgeo.org
Fri Aug 13 06:23:52 EDT 2010
 Reporter:  jng           |         Owner:
     Type:  defect        |        Status:  reopened
 Priority:  low           |     Milestone:  2.3
Component:  Build System  |       Version:  2.2.0
 Severity:  major         |    Resolution:
 Keywords:                |   External_id:
Comment(by jng):
 Oem.sln doesn't load cleanly in VS express because it contains a C#
 SQLiteGUI project which is not used (confirm?).
 Attached is a patch that removes this project. The solution file as-is can
 be built, but you just have to ignore an error loading the SQLiteGUI
 project. This patch is just for completeness.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1413#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
