[mapguide-trac] #1426: Update wix installer file offsets for 2.3
MapGuide Open Source trac_mapguide at osgeo.org
Sun Aug 22 20:07:47 EDT 2010
   Reporter:  jng        |       Owner:
       Type:  defect     |      Status:  new
   Priority:  low        |   Milestone:  2.3
  Component:  Installer  |     Version:
   Severity:  trivial    |    Keywords:
External_id:             |
Description changed by jng:
Old description:
> r5070 introduced 2 new files that has shifted the referenced file offsets
> in the IIS wix source file.
> As a result, IIS configuration is broken with a trunk installer.
> Changes cannot be made however, because a installer branch has been made
> for the 2.2 stream. Until this is done, this and other other 2.3 related
> installer tickets can't be worked on.
New description:
 Changes cannot be made however, because a installer branch has not been
 made for the 2.2 stream. Until this is done, this and other other 2.3
 related installer tickets can't be worked on.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1426#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
