[mapguide-trac] #1421: OGC WFS 1.1.0 Support
MapGuide Open Source trac_mapguide at osgeo.org
Tue Aug 31 03:14:32 EDT 2010
   Reporter:  liuar          |       Owner:  liuar
       Type:  enhancement    |      Status:  new
   Priority:  medium         |   Milestone:
  Component:  WFS Interface  |     Version:
   Severity:  minor          |    Keywords:  WFS
External_id:                 |
Comment(by liuar):
 1. Enhance the Feature Service interfaces !GetWfsFeature by adding a
 parameter to specify the WFS version.[[BR]]
 /// \brief
 /// Retrieves feature information based on the supplied criteria with
 specified
 format.
 /// \note1
 /// <!-- Syntax in .Net, Java, and PHP -->
 /// \htmlinclude DotNetSyntaxTop.html
 /// virtual MgByteReader GetWfsFeature(MgResourceIdentifier
 featureSourceId,
 string featureClass, MgStringCollection requiredProperties, string srs,
 string
 filter, int maxFeatures, string wfsVersion, string outputFormat);
 /// \htmlinclude SyntaxBottom.html
 /// \htmlinclude JavaSyntaxTop.html
 featureSourceId,
 String featureClass, MgStringCollection requiredProperties, String srs,
 String
 /// \htmlinclude PHPSyntaxTop.html
 featureSourceId,
 string
 /// \param featureSourceId (MgResourceIdentifier)
 /// The resource identifier defining the
 /// location of the feature source in
 /// the repository.
 /// \param featureClass (String/string)
 /// The feature class containing the features to retrieve.
 /// \param requiredProperties (MgStringCollection)
 /// The collection of properties to retrieve for each feature. If the
 /// collection is null or empty, all properties will be retrieved.
 /// \param srs (String/string)
 /// The spatial reference system in which to return feature geometries
 /// \param filter (String/string)
 /// An XML string containing the definition for an OGC filter
 /// \param maxFeatures (int)
 /// The maximum number of features to retrieve. If the value is less
 /// than or equal to zero, all features will be retrieved.
 /// \param outputFormat (String/string)
 /// A string identifying the output format of
 /// the retrieved feature information.
 /// The supported values of output format are specified in OpenGIS Web
 Feature
 Service (WFS) Implementation Specification - section 9.2
 /// http://portal.opengeospatial.org/files/?artifact_id=8339
 /// \return
 /// Returns an MgByteReader containing the requested feature information.
 virtual MgByteReader* GetWfsFeature(MgResourceIdentifier* featureSourceId,
 CREFSTRING featureClass,
     MgStringCollection* requiredProperties, CREFSTRING srs, CREFSTRING
 filter,
 INT32 maxFeatures, CREFSTRING wfsVersion, CREFSTRING outputFormat) = 0;
 2. Implement the !GetWfsFeature in !ServerFeatureService to support GML
 3.1.1 format.
    Update the default output format of !DescribeFeatureType and
 !GetFeature to GML3.[[BR]]
 3. Update following items regard to the test suite of OGC CITE
    Update the DefaultSRS to urn:x-ogc:def:crs:EPSG:4326
    Update the format element name from <ows:Format> to <Format>
    Update the namespaces in !GetCapabilities response document
    Update the child element sequence of <ows:ServiceIdentification>
    Add GML 3 support for !DescribeFeatureType and !GetFeature response.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1421#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
